raise your car
    find a friend with a lift
    spoonsportsaddict
      I used to hit a switch, and raise the car...
        so uh, my driveway is at an angle, is using jack stands ok?
        how do you make sure the car sits nice and tight?
          How big is this angle?
          I use cut up tree stumps.
            i wouldn't work on any surface that has an angle, you never know when **** just happens, then the car falls on you.
              When you select jackstands, make sure that the supporting arm at the point where it meets the car does not curve downward to too big of an extent. I found that out the hard way when I bought a pair of craftsman jackstands. I went to support my car but found that the far tips of this support would crush into the car before the bottom-most supporting portion would.
                Originally posted by customlowz View Post
                i Used To Hit A Switch, And Raise The Car...
                Lmfao!
                  Do it in the garage. They are usually level. Thats what I do to mine since my driveway is at an angle.
                    yea i ramps if im working under the car but major job i have used a chain hoist to raise my car up lol
                      jack stands are the way to go and its safe
                      I LOVE MY RHD HONDA
                      I DO WIRE TUCKS AND ENGINE HARNESS!
                      THEWHOLEKREWMOTORSPORTS
                      ALLTHINGSPROPER.COM
