93 ex w/h22 sputters
    like the title says my car sputters and doesnt let me go above 3k rpm when its cold... i have to let my car warm up until the temp gauge sits half way before i can drive it... even when the car is only reading 1/4 way on temp gauge it still does it... i just ordered a p13 ecu and a p19 tcu and should be here next week. you think it having the wrong ecu is causing this? and if it is why does it run right after its warm?
    its running on a POA ecu and a PXO tcu
    i am pretty sure it would be the ECU. it's probably just not getting enough, or too much fuel or something like that.
    but thats the most likely issue
      i hope thats the only problem... since i ordered it already. any other possibilities?
        i have heard similar symptoms coming from a bad igniter. also could be timing.
          ok thanks, i will look into that
