so its all stock and looks like all original. i got tokico illuminas now. my sway bar endlinks are bad. i need to replace those. most of my other bushings around the front wheels look bad too. could i change those as well? or do i need to replace the whole part/parts? i doubt any of it has been changed. how much should these parts run? any suggestions or recommendations on manufaturers? thx!
pretty stock suspension aside from struts/springs
Check out the Energy Suspension urethane bushing set for our cars. It runs about $100, and will likely cost you a bit to have some of the more difficult ones pressed in... But man, does it make a difference!
cp[mike] has an inferior suspension setup compared to my car as far as struts go... but he has the ES kit, and his suspension feels fantastic. It's one of the best upgrades you can do.
Originally posted by deevergote. View PostCheck out the Energy Suspension urethane bushing set for our cars. It runs about $100, and will likely cost you a bit to have some of the more difficult ones pressed in... But man, does it make a difference!
I just wanted to add to the above quote that although the original bushings need to be pressed out. The energy suspension bushings are just pushed in by hand. I am very happy to say all future bushing related issues will be press free. So not only do I get a better ride I also don't need a shop if one ever goes bad again.
I'd also suggest adding a set of sway bar bushings as well. My car has a 22.2mm bushing/Bar. Energy suspension said it was a 25mm. Needless to say I still need to get those in the correct size so check them before you order. (These are the bushings holding the bar to the bottom of the car. Not the end links).
good luck
