how do i remover a tie rod end
    I have to get my right tie rod end off of my 92 accord and I can't figure out how to get it off. Does anyone have a DIY for it or can anyone let me know how to get it done?
    thanks
    there's a jam nut you have to undo.
      do you guys have pictures of the tie rod? i would like to see what are you guys talkin about cause probably my tie rod are gona have to b changed too TIA
        the second picture in this thread is your tie rod end
        http://www.cb7tuner.com/vbb/showthre...hlight=tie+rod
        and theres a DIY on removing it, but the pictures dont work
          when u crack the tie rod loose and are ready to spin it off, make sure u count the number of full turns it takes to come out. Then when u put on the new one, screw it on till u reach the # of turns it took to get off. ( if it took 20 full turns to take off, do 20 full turns when putting it on) this way your alignment will be as close as possible to before. You may need alignment after replacing tie rods
          Hold On Not Done Accelerating
          Had One Never Did Again
            dam [no homo] but i love u guyz n girlz!! lolz ya give the perfect help and information to every noob in here like me... shyt it saves me alot of money for doin the job myself n on top of that it gives me more experience for me cause this is what i want to be..[a mechanic] so im also planin on goin to technical school for this..
              The spin on 20 times, spin off 20 times doesn't always work. Some OEM and Aftermarket ends I found from experience are not the same size or legnth. Acctually I've never had a tie rod the same. Just a thought.
              GOT F?
                just remmeber technical school is just a guide or a stepping stone but it is actually yourself that will want to learn this shit. im in school too, but after being in engineering school and all that school crap. this is what i finally want to learn and do.
                push yourself to be the best
                  Ya I hear ya. I went through years of auto training and now I'm on my own. Things are goin good. A little slow in the fall/winter tho. Oh well, it's expected.
                  GOT F?
                    okay, i gojo'd my hands,(huffing and puffing the whole time) sat down at the computer and started this thread while completely frustrated...i was doing my first rotor replacement and just kept running into problem after problem after problem...after coming in, collecting my thoughts, centering myself and reading a few posts, i realized how easy it was going to be to take the tie rod end off...
                    so i took it off and replaced it with a new one...
                    i didn't realize that replacing both front rotors and pads was so involved...fun though!
                    thanks for the help guys.......
                      .......thanks for the tip, i also had a rust colored line to help mark it...lol, this car needs some tlc!!
