Gentlemen
I searched of course. I'm driving home in my 1993 Honda Accord notice the speedo and tach aren't working then they start working. Car still running smooth. A mile later it stops, and as subject says it'll turn over run for a second then cutoff. I started it one time with gas pedal pressed down, engine went to 3000 rpms then cut off. It must be getting spark or car wouldn't start and run at all. Same with fuel. I did replace cap and rotor recently, no problems until today. I do have a low idle problem but once car is underway engine would run fine. I soldered the main relay a while back for an intermittent no start problem. I'm wondering where to begin. I have a factory service manual. I've noticed my battery is starting to get weak. I wouldn't think that should matter if the car was running then cut off.
Adrien
Adrien
