Accessing Antenna Mast
    So, I've poked around in my trunk and can't seen to figure out how to remove the panel covering the antenna. I need to put in a new mast as mine is stuck in the up position. I've not been able to find any screws/clips/etc to remove to get it off.
    The only clips/covers I've found are at the rear of the car near where the trunk latches, and there's nothing below them, and they were a pain to get out.
    Help please?
    Thanks in advance.
    2000 Acura TL-P - Daily
    1993 Honda Accord SE - Sold
    1996 Infiniti J30 - Sold
    1997 Honda Civic EX - Sold
    1996 Saturn SL2 - Totalled
    1982 Mercedes-Benz 300SD - Sold
    1982 Mercedes-Benz 240D - Totalled
    If you are talking about the carpet like material just pull it! Once you pull it you should see where it is held at. Not for sure where the plastic clips are. Just pull the material and it should seperate. Once pulled the antenna mast will be exposed. I think there are 2 10mm bolts that has to be removed to get the antenna out. Oh yeah one more thing, you got to remove the cap off the top of the antenna inorder to remove it completly out of the quarter panel.
      ^ yeah just pull the carpet like stuff..and bam! =]
      Ride: 2002 Lexus IS300
        x2 Just pull it out of the way. You'll have some wiring to unplug but everything else is exactly what the above post says. GL
          once you get the panel back, there's one 10mm bolt holding the assembly in. there's also a lock ring that you unscrew at the base of the antenna mast, it's on the outside of the car. some people use needle nose pliers to uscrew it. then you just unlpug the wire harness. later.
          Avoiding dirt at all costs
            Oh, thanks. I was thinking there might be some clips/screws holding it all there, haven't tried to just pull on it. I'll give that a shot.
            I tried to just push my antenna down from the outside before and it's stuck up. Is it possible to lower it from the inside?
              yeah just turn on the radio,then quickly turn it off & go out side & push down on the mast as the motor is working.
              or you can cut it
              93 Accord LX Sedan (sold)
                The motor works, but the mast is stuck up, I've tried pushing down on it, no success.
                  Problem solved. Was messing around with it today and just pushed it down with a little more force and now it works again. I guess it was just jammed.
