is there anyway to bypass the fuel cut off/top speed limiter?
higher top speed?
This topic is closed.
I top out at 124-125... Its the very top of 4th gear, at like 6,000 RPM's. Then I shift into 5th and.... nothing. Ive only gone that fast once, not really any need, i'll do around 100-110 every once and a while but thats about it.
_____________________________________________
2 year ASE Certification/Auto Technician Degree completed
There's a thread on how to use all the F22a6 parts if you have any of the inferior motors. With all those parts the pt6 ECU will work in harmony with no speed limiter.
I've taken mine over 130mph. Gotta say though I highly recommend an upgraded suspesion, bushings, strut bars, and everything that might fall off at these speeds. Its a whole different ball game after 110 in an old car, every mph you could be closer to death.
Originally posted by tonymontana1204 View PostThere's a thread on how to use all the F22a6 parts if you have any of the inferior motors. With all those parts the pt6 ECU will work in harmony with no speed limiter.
I've taken mine over 130mph. Gotta say though I highly recommend an upgraded suspesion, bushings, strut bars, and everything that might fall off at these speeds. Its a whole different ball game after 110 in an old car, every mph you could be closer to death.VTEC DUDE!!!!!!!
My 5.7 LS1 Holden Ute
Originally posted by chopshoptuner View Posti do track days and small races and i keep up with everyone untill i get to around 120
And yes, the PT6 (92-93 EX ECU) has no limiter as far as I know. It'll be a direct swap. To get the full benefit of it, you should swap the cam, exhaust manifold, and intake manifold over as well. You'll also gain 10-15hp over your current engine with those things.
