couple of problems/ need help
    First of all, my car has a weird idle. It will rev at about 1k which is normal but then it will shoot up to about 1600 then back down to 1k, then back to 1600, then back to 1k and so on. It's not present when at driving speeds just at idle. This NEVER goes away and its pissing me off.
    Hmmmm, ur idle problem is probably ur EGR valve under the throttle body, very common in hondas. Ur clutch shouldn't be sticking to the floor if u just got it replaced! I hope u didn't abuse it, cuz as they probably told u there is a break in period, 500miles to be safe. Thas wat I think, let's see wat other members have to say
    VTEC DUDE!!!!!!!
      Originally posted by bikener View Post
      First of all, my car has a weird idle. It will rev at about 1k which is normal but then it will shoot up to about 1500 then back down to 1k, then back to 1500, then back to 1k and so on. It's not present when at driving speeds just at idle.
      Also, my clutch seems to be a bit feathery. This has happened about 5 times in the past day. I will clutch, have a rough shift and then when I remove my foot from the clutch it would stay down. What could this be???
      I just just got my clutch replaced so I'm hopping it's something minor.
      For your idle - Clean out the IACV (on the front of the intake manifold), and clean the EGR.
      For your clutch - Sounds like the clutch master and slave cylinders havn't been blead properly and still has air in the lines.
      Give it a bleed and it should come right
      My 5.7 LS1 Holden Ute
        The idle could also be the FITV.
        PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
        Listen or download the first 4 songs I completed for my new upcoming album here!!
        My member's ride
          wheres the egr?? Any precautions i should take when cleaning it??
            cmon guys help me out, I've already cleaned my egr and the front of my intake manifold but it hasn't helped. I read a link that said to turn the ring around the air bypass valve to the left and it will fix it. What is the air bypass valve and where is it???
