wass up guys im needin some help here this is my first time doin my oil change for my H22a and i just need to know whats the oil type and wieght that you guys best recommend and oil filter if u guys can help out a cb7 bro id really appreciate it thanks again
Oil Change
Ok so you have a h22. well we need to know a general mileage. are there any power adders? alota people will tell you a million different things cuz alot has to do with preference and brand loyalty( i've always used brand xxx) really what has been tested is that Amisol and royal purple are some good oils.
Amsoil is quite possibly the best money can buy.
I generally use Castrol or Pennzoil synthetic blends... but my H22 is going to be rebuilt (well, removed for a rebuilt one)... so I'm not exactly focusing on keeping it in perfect shape. The one in the car now will be for spare parts, and another build down the line.
i say you don't need ton use synthetic. it has more detergents in it thus helps keep your motor clean. but i have heard of a lot of problems if you switch right back to conventional.
Sure, it's an H22. but it's still a motor. Still works the same. what you should do is get oil for your driving style. If you just drive it for now and could use the little bit of extra $$$ for other things while your workin on it, i just used 5 quarts of castrol gtx and 1/2 quart of lucas.
I am going to switch to better oil once i get everything settled.
Mobil 1 or Royal Purple is good. I also would use the Mobil 1 oil filters...they're made really well. Should be 5w30 for the viscosity.
I used to run nothing bu Mobile 1 SuperSyn, but after seeing 2-3 tests confirming that the Mobile 1 Synthetic is only better than dino oils in that it has more detergents and a higher flash point (no better lubricity), and seeing some tests on Amsoil and Royal Purple that beat everyone else by a wide margin in every designator, I switched to Royal Purple. I recommend Royal Purple or Amsoil, if not these I use Castrol GTX to do friends' oil changes.
Royal Purple and Amsoil are the only two that I know of (maybe Redline also) that have a zinc additive in the oil which is one of if not the best anti-friction additive an oil can have. fwiwMy Member's Ride Thread
Here is a lil hint about getting some cheap synthetic oil.
Go to Walmart and pick up some Syntech synthetic.... if you live on the east coast its probably Mobil 1... west coast its probably made by Shell. You can compare the markings on the bottles to those counterparts and figure out who manufactured it.
The regular stuff is made by Warren oil and its top quality stuff too just with out the multimillion $$$ ad campaigns.
I picked up 5 quarts of 5W-30 for my moms Explorer a few months ago for $12 where the mobil one was gosh maybe $25-30... its never run smoother.
Also I would take a Syntech oil filter over a Fram anyday... They are better made and more efficient and cost half as much. Fram = crap Though I've never had a problem using their air filters. Wish walmart would start using that crazy buying power for air filters and fuel filters too!
Total cost of an oil change with Syntech stuff should be no more than $15 for full synthetic and an OEM quality filter.AD5OS
FOLDING@home
Originally posted by 1sickcb7 View Postok this is what ima do ima buy 5 Royal Purple / 1 qt. SAE 5W-30 High Performance Motor Oil with Mobil 1 oil filter ?? is this correct or Royal purple with SAE 75 140W and diff. oil filter?
