wheels
    wheels
    ive had this problem for a while, my car shakes while driving... thought it was my wheel bearing but come to find out its actually my wheels that are bent.
    what is the cb7 wheel pattern 4 x 1**
    also what honda wheels fit the cb7?
    4x114.3
    Ride: 2002 Lexus IS300
      thanks for the quick response...
      now i just need to search and find out what other honda wheels are that same wheel pattern.
      is there any way to do a 5 lug conversion to use the s2k wheels, has anyone done this?
        I suggest you check your local Craigs list. I see new and used wheel sets newly posted every day.
        As for the conversion I read about it once and sounded fairly easy. I just didn't see what the benefits were so I forget how it was done. Sorry
          ok thanks.... i hav e been checking craigslist... found some s2k wheels thats when i became curious about the conversion.... from the search i here there is an adapter you can buy to convert to 5x114.3 which is what the s2k is... dont know the reliability of these adapters and if anyone has used them, your experience with them would be appreciated
            well there are a few 5 lug swaps but the s2k isn't going to be the best way. probably more expensive. i think i remember reading about an odyssey swap. not sure if you would get the Rotor-over-hub advantage as well though. contact tsauto about it. they would probably get you a much better price.
              ill check them out and see... whats this rotor over hub advantage your talking about?
                also ive read ppl using the 5th gen (97-01) lude brake setup...
                also other honda wheels of the 4x114.3 are the 4th gen lude wheels (92-96)
                and if you want aftermarket..... the 240sx (before 95) all shares the same bolt pattern, so aftermarket is really available at the right price... just be careful of the offset
                  There's a sticky thread in the Suspension forum that shows all OEM Honda wheels that fit our cars.
                    thanks i will check that... what should the offset be?
