How to get Lower and Upper Balljoint loose
    How can i get lower ball joint and upper loose.
    I took off the castle screw and hit the side of the knuckle to get it loose but it doesn't come off.
    You need a ball joint puller... and then a big hammer to whack it out.
    The upper ball joint should not be removed. The entire arm should be replaced.
      balljoint is good... i just need to remove the knuckle so i can take off the rotor wheel bearing and hub and put in Rotor over hub setup.
      I guess i have to go and get ball-joint remover
      like this one i guess
        try jacking up the lower control arm then hit the upper ball joint.
          That's it right there. You can rent a kit for free from Advanced Auto Parts. Not all the stores do it though, so call ahead.
          Pretty easy little job.
          Originally posted by Maple50175
          Oh here we go again. Maples other half.
            I just hammer the top part of the screws and it pop off
            I can't take the castle nut from the bottom off because my impact gun is too big ><
            i think i'm going to homedepot to buy right angle cordless impact wrench and get it off
              You don't need an impact gun for the castle nut anyway. It shouldn't be on there that tight. Honestly, there's very little on our cars that you NEED an impact gun for.
                apparently that is soo wrong....... look like my car all the bolts was tight too tight
                i can't get castle nut out even with ratchet ><
                I can't get caliper pin out even with impact gun.....
                i'm about to quit and burn this car ><
                  Then the chances are that someone used an impact gun to put everything on...
                  That, or you have not yet mastered the art of the huge breaker bar.
                    i dont have no breaker bar
                    can't drive to get it because my car in pieces ><
                      I dont know man I seen too many people hold a wrench in the wrong position most of the time and they fail to grip it right......anyways I don't use actual breaker bars what I do instead is add a hollow piece of steel tube that fits onto the 1\2 rachet!
                      Its ghetto time! This is my adjustable manual torque wrench!
                        sup bro, for the lower ball joint I do it like this: put a 3/8 ratchet handle(the flat kind) in between the arm and knuckle and step on the top.
                        Originally posted by kc8enb07
                        does it come w/ jdm trash? they better throw away gold in it
                          On the upper joint I just changed the entire arm. Pretty cheap really.
                          The lower joint is a pain. However my first ball joint change I used a huge punch and a BFH to get it out then the same to put it in (I don't suggest this). Within a few months I paid a shop to remove and install another new joint.
