Hi,
At this point my accord is to the point where it will require over 1 qt of oil per 1000 miles, the car runs really smooth, no problems, gets up to speed normal nothing out of the ordinary. Somehow this car will consume a lot of oil. I do know that the seals are bad (blue smoke at start), but at the same time I do not to put any more money in this engine.
Just today I found a used engine out of 97 Accord V-tech with 85,000 proven carfax miles. At this point I am willing to swap the engine and continue with my life.
My question is:
Will that engine fit without modifications?
ECU?
Axels?
Can I use my old transmission?
Basically what is involved in the engine swap?
Is is worthily to spend money and time on this project?
Do I have to change anything else on the car?
I know there are a lot of questions, but of you can answer some of them I will appreciate your help.
Thanks!
My question is:
ECU?
Axels?
Thanks!
