ECU code questions
    ECU code questions
    I pulled the codes off of my ECU on my 90 accord F22A1 and have a couple of questions. I got a 7 code followed by multiple 17 codes ( I stopped counting them at 13 )
    Does a code set itself just once or multiple times
    Can the first code set off others?
    Should I have waited to see if any more codes came up?
    LIVE FREE OR DIE
    shouldn't duplicate codes, sure it wasn't just 17 over and over and the 7 was a mistake? that would make more sense.
      So you have a code 7 (TPS)
      Then through 17 more codes? or a code 17 (VSS)
      3 CB's gone....
      1 WK Overland....
      Still miss the CB though......maybe one day.
        It sounds to me that he's saying one code 7, and then repeating code 17.
        Souds to me that it's probably JUST the code 17. Either you're not counting the first flash, or it's doing it in a strange way.
        I'd replace both sensors just to be safe. Never hurts to have new stuff on your car... or at least junkyard parts (the TPS is held on by headless screws... use a hacksaw to cut notches in them... you do not have to replace the entire throttle body as many people believe. It must be properly calibrated, though.)
          OK 1 code 7 and at least 13 code 17's stopped counting them at 13 times on the code 17. Don't know about the first flash you mention deervergote. I jumpered the plug then turned on the key so I wouldn't miss any because I haven't do that to this car before.
          As for the TPS calibration do you mean if I use used TPS? Get a hack saw in there? I can't get my hand in there with my multimeter probes to test the damn thing. Which has me ask. The manual says to probe the inner and 1 of the outer terminals on the TPS and crack the throttle to read the resistance on the TPS. Anyone know a different way cuz I don't have go go gadget arms.
          All of this is in following one of the threads from one of the big dogs on here trying to fix my damn erratic idling problem. Could the VSS cause erratic idle?
          LIVE FREE OR DIE
