hey people..im planning to do a h22 swap but its too expensive...i was wondering if a JDM F22A 2.2 SOHC VTEC will fit into my 91 accord 2dr lx.???anyone of you guys can help me???
JDM F22A 2.2 SOHC VTEC Swap....???
F22A's don't have VTEC. You are probably thinking of the F22B SOHC VTEC which is VTEC for fuel economy NOT performance as like with the H22A.
EDIT: If you ARE asking about the F22B VTEC, then yes you can swap it in but it isn't really worth it from what I have read. BUT that is from what I have READ and HEARD though. Not from experience. There are more eligible choices than just the H22. You should try researching a little more.Last edited by Father Time; 10-22-2008, 01:02 PM.3 CB's gone....
1 WK Overland....
Still miss the CB though......maybe one day.
The F22A came in the JDM 91-93 Accord Wagon, its the JDM version of the F22A6.
I looked on Tiger Japanese, and H22A's can be had for $750 without transmission, you can just hook it up to your accord trans. link here
The F22A's can be had for $890 link here
Or you can rebuild the F22 you already have for cheap and slap in a good (bisimoto) cam and do some head porting. That would put you at about 150-170 whp, depending on which way you go with your setup. Thats pretty much what a stock H22 would put out.
Research my friend, and you will discover everything you need here. I figured out everything I needed to know about my wagon from this forum.
Originally posted by kenjin View Postthanks people...i am looking forward to a h22 swap because it has more power...but i was wondering if you would have to too all the paper works for the f22 vtech too....besides i think the h22 swap is too much work for me...
Oh, and it's VTEC Honda never incorporated toys into their engines.3 CB's gone....
1 WK Overland....
However, the F22B1 is a garbage engine that only has 5hp more than the F22A6, and significantly less potential.
THE F22B1 IS NOT AN UPGRADE!
the h22 is actually one of the easiest honda swaps there is.....and on the 7th day, deevergote rested and called his mom.
