Originally posted by djdimasik
View Post
How to install keyless entry (no alarm)?
My inferiority complex isn't as good as yours.
Originally posted by 93accdpj View PostThe lock relay supplies the ground. Put a test light probe to the red/black wire on the connector, and the clamp on a power source the test ligh will come on when you hit the lock button one way. The black/white wire will light the test light when you push the lock button the other way.
thanks guys
Here is some basic wiring info for our vehicles. I'll probably do a write up with pics soon....may just take mone apart to show, with full remote start. Keyless is a breeze. those two wires for locks, plus power and ground.
this shows wire colors and locations.
Item Wire Color Polarity Wire Location
12 Volts white + ignition harness
Second 12 Volts
Starter black/white + ignition harness
Second Starter
Ignition black/yellow + ignition harness
Second Ignition
Third Ignition
Accessory yellow + ignition harness
Second Accessory
Third Accessory
Keysense
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock black/white - lower drivers kick
The station wagon uses green/white for lock and yellow/white for unlock. These wires are found either in the drivers door harness or under the rear seat. Locate the large harness in the lower below the carpet in the drivers kick panel. Near the foot rest you will notice a piece of blue tape attached to the harness itself. Reach around to the underside of the blue tape to locate a 2 pin gray plug with the lock and unlock wires attached to the plug.
Power Unlock black/red - lower drivers kick
Lock Motor
Driver Unlock Motor
Passenger Unlock Motor
Parking Lights (-)
Parking Lights (+) red/black fuse box in dr. kick
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight blue/red or blue - steering column
AutoLights
Reverse Light
Left Front Door Trigger black/white - brown plug left of column
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision
Trunk/Hatch Pin green/black - green plug left of column
Rear Glass Pin
Hood Pin
Trunk/Hatch Release
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Trunk Alarm Shunt
Tachometer blue AC distributor
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense
Brake Wire green/white + at brake switch
Parking Brake
Horn Trigger lt. green/blue - column or horn relay
High-current ground. Use a relay when interfacing with this circuit.
Wipers
Left Front Window (Up/Down) red/yel - red/blue A drivers door switch
Right Front Window (Up/Down) blu/grn - blu/yel A in drivers door or dkp
Left Rear Window (Up/Down) green - grn/yel A in drivers door or dkp
Right Rear Window (Up/Down) yel/grn - yellow A in drivers door or dkp
Sun Roof (Open/Close)
Sun Roof (Limit/Close)
Memory Seat 1
Memory Seat 2
Memory Seat 3
Radio 12V white/yellow + radio harness
Radio Ground black - radio harness
Radio Ignition yellow/red + radio harness
Radio Illumination red/black + radio harness
Factory Amp Turn-on N/A
Power Antenna yellow/white + radio harness
Left Front Speaker (+/-) blue/green - gray/black +,- radio harness
Right Front Speaker (+/-) red/green - brown/black +,- radio harness
Left Rear Speaker (+/-) blue/yellow - gray/white +,- radio harness
Right Rear Speaker (+/-) red/yellow - brown/white +,- radio harness
Bought from: TypeG,mak,CB7_ACCORD,ChampCoupe,Blackex
Traded with: Cb7xChun
Sold to: Rob_is_legend,DaddyO,daheavyking
Sedan MR Thread Coupe MR Thread Prelude Si MR Thread
My huge For Sale Thread
