battery light still on
    ok i've posted before about my batt light staying on i swapped alternators once so far, but that isnt my problem cuz i've wen around the engine bay w/ my multimeter an checked batt volt, alt volt, ELD volt, batt gnd, starter gnd etc... car charges. now when i disconnected the - clamp an connected my meter via post to clamp and switched my meter to continuity w/ radio(backup) & interior lights fuse out i lose the beep. How do i go about diagnosing these wire i have no idea were to find them.
    I think its time i deal with this batt light plzz help
    Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
    CLICK THE PIC
    reset ecu and see how it goes.
    MY MEMBER'S RIDE TREAD: http://www.cb7tuner.com/vbb/showthread.php?t=118186
      bump
      CLICK THE PIC
        x2
        I had this same issue.. my car died while driving, literally my police radar was reading 8.8 as my voltage on my battery!!!!!
        I would take your battery to auto zone and see if your battery is still good, that's what my issue was, it was my battery. If it checks out okay do what josh's_cb7 said and reset the ecu
        Originally posted by Juice21
        thnx pimpette, your car inspired me to go lower
        Originally posted by GameChewer
        Shiit i heard that, you heard the queen!
          read 1st then reply my batt is good an it charges. car ran on hwy for a longtime an no problems i just want the light off Next
          CLICK THE PIC
            There is a green plug that plugs into the alternator... 2 of those connections are responisble for that light.... I would get some electric connector cleaner and spray that in there and try to knock out any corrosion. Also on mine I found the insulation around the wires to that plug to be very brittle and cracked off. I taped them up so they were not shorting out with each other. So check your wires to that plug and put some electrical tape around them to protect them.
            Also just for what its worth I find that the tests that some autoparts stores do for your battery or alternator to be flawed... usually with them wanting to sell you a new component and whatnot.
            AD5OS
            FOLDING@home
              bump
              CLICK THE PIC
