ROH Kit from Tasauto Any good?
    If you need the parts in a pinch, TAS is def. the way to go. But, if a ROH project is planned for the future, def. try to hunt down a 98/99 2.3 CL being parted out (jyard, craigslist, ebay...), you can often find a good deal on the front knuckles. I recently found a CL and got a good deal myself, but I have been searching for awhile, CL's are sorta hard to find, at least where I am
      lol true man
      back at it again
        I just got my stuff
        1 Day to get it shipped from CT to NYC
        - The Hub is Honda Genuine part - Part # 44600-SY8-A00 Acura CL Front Part
        - Wheel bearing is already pressed onto the hub. Not sure if that a honda part or aftermarket.
        - Brake Pads are AutoPart International - Ultra Series
        - Brake Rotors are also Autopart International
        This is awesome Can't wait to put it in tommorow.
        Is there anything i should watch out for?
          I have failed.....
          Cannot take off the caliper pin - it seize on that thing
          Cannot take off the lower ball joint castle nut - Impact gun too big to go under
          Piss off at the car - Priceless
          Total money spend in this project - $500
            Take a break. Have a KitKat. Or Mentos. You can do it. Maybe a torch or heat gun would work? Just an idea...
              I will try heat gun....maybe on sunday
                That's the spirit!
                  oh also...after seeing that my car not going to last for awhile....I think i'm going to sell the CL Hub/Bearing on here or something.
                  After jack up my car I saw that there were oil dripping slowly (only when car in the incline from tranny and Oil dripping from the engine somewhere..........
                  I might just going to replace the brake pad and rotor only
                    Originally posted by XcluziveAZN View Post
                    I have failed.....
                    I always usually end up using a box-end wrench for the castle nut.
                    Gary A.K.A. Carter
                    [sig killed by photobucket]
                      my cb7 leaks alot keep the cb7.
                      back at it again
