Stupid Clutch!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Well I Just Bought A Clutch Kit And It Not Working Properly I Put New Cvjoints And A New Slave Cylinder The Gears Go In But The Car Wont Move
    could be the tranny cables from the shifter
    Maple50175 - you're annoying =P
    Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
    JoshM - Crotch rocket = chick magnet.
      did you use the clutch alignment tool properly? and how is the transmission oil?
        i think he would know if it was this... the shifter would be sloppy and all over the place wouldnt it?
          i would say tranny...same thing happened wit my boysz whip
            MORE LESS GOT IT WORKING STILL NEEDS A WHOLE BUNCH OF BLEEDING
              It's usually in the bleeding. I still need to bleed mine again.
              It's never a good idea to replace your hydraulics AND your clutch at the same time if you don't need to. Better to use the old hydraulics to break in a new clutch properly, if it all works as it should... or replace the hydraulics and allow the old clutch to take the beating as you work out the kinks.
                really. dang i hope i dont have that problem when we swap my car to a manual. cuz i am buying a new clutch and new hydraulics
                  lol same but at least i picked up the old slave and master also from a manual car, they look good
                    Well, you kinda HAVE to do it that way...
                    It's not a bad thing to do, you just have to be sure to bleed properly. If it's your first time bleeding a clutch system, I would suggest getting help from someone that has done it before. Having a pump to do the bleeding helps a whole lot too.
                      i got a pro coming to help with the swap and he has done this before so lets hope everything goes ok
