From what I gather. To replace the ball joint requires an entire arm unless you install a camber type ball joint. Might as well buy the whole arm and either use the stock bushings or replace the bushings in the new arms if you already ordered them.
I just added the energy suspension hyperflex to mine last week. I used a friends press to remove the OEM bushings but was able to install all of them by hand, except the later added rear lower strut bushing which the bolt had rusted and broke off in.
Good luck
Good luck
