WHat up guys. 1st off i have a noisy centershaft, i am aware of this.
My car has developed a strong shaking in the front end from exactly 15 mph to 25 mph. It does this regardless of which gear (1,2,3). However, i hit a large pothole last night and the shaking became less pronounced. I DO NOT beleive it to be a bent wheel.
Today, as i drove to work, i loud whinning sound started to come from the front end when the car moving, and became VERY loud when i would brake while the car was in gear.
2 days ago, i backed into a parking spot and the car became stuck in reverse. It took both hands and all i had to get it outa reverse. Then today i parked again and attempted to back out and the car would barely move. It was almost like i had a foot on the brake when i tried to move. Finally it would move, and it started to smoke alot underneath. I suspected the clutch, simply becouse how high i had to rev it to get it to move.
Just so you know, ive never owned an automatic, so i can drive a clutch very well. And, the clutch in my car was replaced 20K ago.
I stoped in another lot to try reverse again, and it worked, but i had to release the clutch very far to get it to go. All forward gears seem to engage just fine. I only put about 15 miles on the car sense this happened, and in that time, the whinning became so loud i could hear it over my 2 12" set on blast. Its really staring to make me nervouse.
My car has 40k miles on the motor, 20K on clutch. and 225K on the 5-speed trans.
Please, i really heed some help guys.
Ohhhh. I checked it out from underneith. All the trans mounts i could find looked good. The CV axles appear to be fine, no clicks or torn boots. When i spin either wheel it makes a grinding sound that i beleive is the center shaft.
Im hopeing this is not the trans...
