Replaced the header and downpipe... and when accelerating at a moderate/fast pace, I hear this rapid "ps ps ps ps" sound. My friend said it sounded like a gasket might be flapping... and what he smelled had an odor of that as well (I thought it smelled like clutch, but he hadn't slipped the clutch at all, so doubt it was that). Anyway, if anyone has any ideas, let me know... otherwise I'll just let the shop take a look at it. Thanks!
Final exhaust question
Originally posted by Medikerik View PostIf you're referring to what I think you are, they were tightened down to spec... if not, I'll go poke around. The headers were torqued to 23 ft/lb like they were supposed to. Or am I mis-understanding the part you're referring to?
http://www.tasauto.com/Product/Brows...z=10&h=175&p=1
I got it off ebay, and it was the one for a 93, but same thing. Same picture, anyway.
If you tightened to spec but the threads were dirty or rusty, you won't get the same clamping force as if for new bolts/nuts so you will have to apply more turning force to get the same bolt stretch. You probably don't want to take it apart and reassemble bcs then you might need to replace the gaskets. But try some WD40 or pb blast on the threads to help you to turn the nuts easier, then tighten them a little more. If you still are getting the leak, tighten a little more when the assembly is hot.
Originally posted by Medikerik View Posthttp://www.tasauto.com/Product/Brows...z=10&h=175&p=1
Edit: Is this like the header you bought?
http://cgi.ebay.com/ebaymotors/90-93...=p4506.c0.m245
If so, I am about 95% sure that your problem is where the header meets the downpipeLast edited by AbsurdNY; 10-15-2008, 08:39 PM.
http://cgi.ebay.com/ebaymotors/_Car-...=p4506.c0.m245
No thud. Just a very rapid sound, more like air escaping than a thud.
