Computer Question
    Computer Question
    Can A F22 Computer Work for a 93 H22a1 Vtec Motor?
    92 nissan Stanza - Junk Happy
    89 honda Crx Si - Sold
    Frost White 91 Honda Accord Lx F22a1 - Traded
    Navy Blue 92 Honda Accord Ex H22a1 Vtec Automatic - My New Baby
    You Can Catch me Ridin In My CB Eyes On The Rearview Lookin For The Police
    I know the TCU can if you've got an Auto H22, but it'll be severly laggin. The shift points will be way low.
    As for ECUs no I think you need at least a P13 or get the better P28 & P72 to make it chipable.
      but wat ecu suppose to come with the motor...and how to wire the vtec is it in the ecu or do i have to do it another way
        The H22A uses a P13 stock ecu. You can also use a P28, but it requires chipping AND tuning. If you don't tune it, you are likely to damage your motor.
        The Swap FAQ explains just about every question you might have regarding a H22A swap (including wiring): http://www.cb7tuner.com/vbb/showthread.php?t=5423
        1992 Prelude S w/swapped H22A
          The H22 will run with the stock Accord ECU (PT3 or PT6), but it won't be right, and you won't have VTEC. That IS in the ECU.
            so can i re wire the vtech
              youll have to add the vtec/knock wires.
              93 Accord LX Sedan (sold)
                i dont kno nothin abut that
                  yeah for vtec you have to get new ecu. and why man, why did you get an automatic?
                    so a f22 vtec can work or not? i wish i can convert it i'll be happy...ima post the pics of the car to sho u
                      Did you look at the swap faq? If you want VTEC, you MUST get an engine and ecu combo that already has it, and you MUST wire it. If you aren't comfortable doing that, maybe you should save up and have a shop do it.
                      Anyways, if you want an F22 with VTEC, you have to swap in an F22B1, which is a horrible motor and is not meant for performance, but for economy instead. The F20A or the H22A would be much better choices.
