I don't know what to do ? HELPP
    hey i have a honda accord that was my daily driver but today i came back from the store and parked it on my drive way shut the key off and took it out and the fan was on(radiator fan) so i though wtf?.....then i turned on the key a couple times to see if there was a short or something...but the sport shift light was flashing to so idk what is wrong with it i took off the battery terminal and there it sets. it is probably an easy circuit or sensor that went out but i don't know what to do help please
    search and you shall find..
    keyword "fan timer switch" and "flashing S light"
      Don't worry about the fans they stay on to cool the engine after the car is driven.
      The flashing S light is your transmission trying to tell you there is a problem, there is a blue 2 pin connector on the passenger side that you can use to find what the problem is. Hopefully someone will help you and post a link here for you to do it. I would do it but I'm on my phone that's too much work for me.
      1993 Accord EX
      2011 Subaru STi
        Exactly correct. I think my fan runs after I shut the car off more then when it's on. The flashing light is a tranny issue, nothing to do with the fan. On mine you simply short the contacts on the blue wire under the passenger side dash. Then turn on the ignition without starting it and it will give you a code I believe. The look up the code to find your issue.
