Vibrating/Shaking in 1st
    In the morning when I back out of the driveway and switch to 1st and begin to go forward the car usually shakes a bit, not horribly but it's kind of like wheel hop.. I'm not posistive if it is wheel hop but it seems like it. This also happens sometimes at the beginning of 2nd but that's rare.. It's worse when it's really cold. My question is.. is it something to do with my suspension.. ball joint/tie rods/shocks? I'm replacing all of that anyway.. or is it the clutch.. can a clutch warp and then do that? I would think I would have the issue in every gear if that's the case.
    Thanks
    My guess would be a worn torque motor mount.. check your dog bone and rear motor mount.
    AD5OS
    FOLDING@home
      Should I be able to visibly see that it is worn?
        Yes, normally they develop a crack right through the rubber.
        It's possible for the clutch flywheel to warp causing a shudder on take off.
        Does it only do it when you are letting the clutch out?
        My 5.7 LS1 Holden Ute
          Yea it only happens when I let the clutch out and it's always worse when it's cold.
            The only real way to check a mount is to take the weight of the engine off the mount and get a screwdriver and see how much you can move that mount around with the engines weight off of it... its a pain in the ass. You could go to the store and get yourself some mount inserts and install those on the mount and see if that helps. I got all my mounts new off ebay for $150... took a few hours to put them in but I did it myself. get a buddy and it will probably only take 30 min per mount and 45 for the rear.
            Another way to test mounts is to get a buddy to watch your engine while you engage it in 1st gear and then reverse while keeping the brakes on. it will really make the engine go back and forth if your mounts are bad. Reverse is usually very telling of bad mounts as it really clunks the engine while you are trying to back up smoothly.
            AD5OS
            FOLDING@home
              Thanks. I'll look into it and let you know.
                mine does it too
                not too horribly worried about it..
                Ride: 2002 Lexus IS300
                  Originally posted by cvc7chris View Post
                  mine does it too
                  Yea mine too! Not a big deal but its annoying, I have an H and replaced the mounts with stock ones, within like 3 months they were bad again!!!(and yes I know I should have put after market mounts, I leaened my lesson the hardway)
                  VTEC DUDE!!!!!!!
