2 codes pulled..
    2 codes pulled..
    ok so this is what i pulled.
    6 quick flashes... which should be Engine Coolant Temp circuit
    and
    2 slow and 2 quick flashes....which is VTEC Oil Pressure Switch
    how would i check these to fix the problem.
    I have a f22 and I just replaced my coolant temperature sensor.
    Mines was right underneath the distributor screwed into the block; right behind the the sensor that sends the engine temp to your temp guage in your cluster.
    if you change it coolant will leak out so do it when the engine is cool.
    and from what i read and i did when i searched you are supposed to hurry up and put the new sensor in so too much coolant wont leak out. and fill the radiator back up.
      First, check fuses/reset the ECU and go for a drive, it might have been a temporary mess up.
      Second, make sure everything is plugged in ok, nothing is loose.
      Third, make sure the wires are in good shape, nothing is broken/shorting out.
      After that, you probably need new sensors. The coolant temp sensor is under the dizzy, I'm thinking it is the 2 wire one. You will have to bleed the coolant system after you change it.
      The VTEC switch is behind the dizzy, you will probably loose a little bit of oil when you replace it.
      1992 Prelude S w/swapped H22A
