Hey guys im new to the forum and I am having some issues with my daily driver, it is a 1992 LX. I have had a few occasions where it wouldnt fire up at all when I try to start it, but after 10 or so tries it starts up. Then a couple days ago, out of no where it dies on the freeway. I pulled over to the side, and after 15-20 tries is starts up and ran fine. It did that 3 seperate times on my drive home. When it dies, it doesnt slowly sputter out, it smoothly just goes off instantly, like flipping a light switch. While it dies, all of my electrical components work fine (radio,lights,blinkers). It seems to idle fairly low also, but that may be unrelated. I switched out my main relay assuming it was that, but it didnt fix the problem. Any input or suggestions, ignition control module?
Problems with my 92
Originally posted by tonymontana1204 View PostAre you sure the main relay you used is good. I would double check it, when was the last time you did a tune up?? There could be many factors contributing to this problem.My inferiority complex isn't as good as yours.
Like the other guy said, the main relay could be bad even if you bought a new one. Also thete might be som shit in your fuel system clogging up the fuel line. But if its the relay you should hear two cliks when you turn on the ignition, you should also be able to hear the fuel pump running. Good luck
I bought the relay brand new at carquest, but I suppose I could have gotten a faulty part (never thought of that). It seems to be getting worse though slowly, and I dont think its fuel because it doesnt slowly die out, its immediate. Im thinking its my ignition module, but I have it at a buddys house who is a mechanic right now
Originally posted by deevergote. View PostSounds like corroded or loose battery cables to me. Clean and tighten the cables and see if that fixes the problem.
I had loose cables, and it would do the same thing to me. just shut off out of nowhere... and sometimes starting was impossible.
That was one of my first thoughts, and I double checked them. Seem fine
