Cb7 is back!!!
    Cb7 is back!!!
    Got it today!!!
    Items Replaced....
    Timing belt, balancer belt, Water Pump, Head Gasket, Intake/ Exaust manifold gaskets, oil, filter...., Valve job , New Alternator and Battery. I figured do It all while I'm throwing that much money into it!!
    It's Running PERFECT. The ony problem is my speedo is stuck pointing straight down!!!! What could cause this...I'm pretty sure the gauge went out....it has 234xxx on the clock.
    If I go to pick'n'pull to get one the connection in the back for the speedo is electronic right?
    Thanks in advance for your time!
    Its not ur gauges its most likely ur SPEED SENSOR
    VTEC DUDE!!!!!!!
