Oil leak -- new seals and gaskets, what else???
    Okay guys...I just got a timing belt job done at a local shop. I also put on a new valve cover gasket set as well as a new oil pan gasket/oil pan plug.
    After all that, there is still a tiny leak/wet spot at the bottom of the timing belt/crank cover. The oil pan is dry (except for the side next to the wet spot). Okay, my oil pan gasket looks good, the oil pan drain plug is dry, and assuming the shop did the timing job right (i might just take it back for the 90day labor warranty), what else might be the culprit of this oil wet spot?? as MINOR as it is...it's unacceptable!
    new parts:
    • Timing belt
    • balance shaft belt
    • water pump
    • new tensioners
    • oil seals
    • balance shaft retainer clip
    • drive belts
    • valve cover and oil pan gasket
    Member's Ride Thread | DMV Summer Meet 2011
    Q: Why is your pants around your ankles? Answer
    Either rear main seal or oil pan gasket.
    Feeding trolls is my profession and hobby.
    I have the ability to speak and write the idiot language.
    Masters Degree on Trolling & Counter-Trolling
      Is it a leak, or just left over residue from after all the work was done?
      Were all the seals replaced - Cam seal, balance shaft seal, and crank seal?
      If they were all replaced and there is still a leak, either one of the seals is possibly leaking again, Or your P/S pump is leaking - The p/s oil can often leak down the front of the covers and appear most obvious at the bottom
      My 5.7 LS1 Holden Ute
        yea, I wiped the whole car down after the work so that i could spot any oil (anywhere on the car) -- drove a few hundred miles, went back under and found the wet area in the bottom corner of the cover. it's not a steady drip drip drip or anything. its wet enough that it probably drips just a little when the motor is running. oil dipstick doesnt indicate any alarming loss of oil and my car doesn't burn oil.
        all 3 seals were done. i bought the oem parts myself.
        p/s looks fine...i guess(?) ill have to double check, but i doubt it has an issue - i havent had to top it off.
          Was there a drip actually sitting there, or just a residue?
          Wipe it off, then recheck it again in 100miles.
          If it is there again, check wether it is better, worse or the same as now.
            I have a feeling i should've payed the guy to slap on a new oil pump gasket...
            That's all i can think of.
              Oil pump doesn't have a gasket, it has a sealer. Or do you mean the rear balance shaft gasket?
                i mean...i didnt realize either...then found this (a set, i guess)
                RockAuto.com Catalog: oil pump gasket
                  it's a cb7 they all leak oil
                  Ride: 2002 Lexus IS300
