ahh, new problem. Alternator?
    So, was drivin'....doin' my thing, drivin' through town, and outta nowhere, my lights started gettin' dim...needles started dropping to zero, and popped back up to where they're supposed to be. Battery light, and anti-lock light came on. Stayed on. So, made my way home (15 minutes). Engine was running fine. I didn't feel a loss in power at all. I came home, turned it off. 10 seconds later, tried to start it...BARELY started.
    So, turned it off...came inside, told my step-dad, we went back out about 10 minutes later, it had trouble starting again (battery was near dead), and it ran fine..no battery light, lights were bright as could be, I got outta the car as he was checking stuff near the alternator, and 2 minutes later, went to get back in the car...lights are dim again, and battery light came on. But we let the car run for 10-12 minutes just idling. So, the alternator has enough power to run the engine, but it's makin' my lights and stuff flicker.
    If I give it gas up to 4,000rpms....battery light goes away (lights still stay dim) When I say lights, I mean.....headlights and dash lights. I turned my radio off. Once I let off the gas, and it goes back down passed 2,000......battery light comes back on.
    My step-dad said something about a part inside the alternator? Regulator? It starts with an R. Says our cars have it.
    98' Mustang 3V Swap
    11' VW CC R36
    sounds like the alternator isnt charging like its supposed to. think the alternator might be going bad.
      That's what I was sayin'. But it's staying charged just enough to run the engine. It's acting like it has a short or something? I took the battery terminals off, cleaned 'em off with sand paper, tightened back up, even relocated the ground wire that dangles off the negative terminal, to the other slot on the fender. Still doing the same thing.
      98' Mustang 3V Swap
      11' VW CC R36
        http://www.cb7tuner.com/vbb/showthread.php?t=42260
        yea. your alternator is slowly dying...soon itll just not start your car anymore and you battery will have already died too.
        Member's Ride Thread | DMV Summer Meet 2011
        Q: Why is your pants around your ankles? Answer
          Welp, just installed a new one today. Fixed the problem. I got it new, so when I do the H swap, I can use it.
          98' Mustang 3V Swap
          11' VW CC R36
            Mine did the same thing on the way home from work just bought a 91 accord coupe ran for a few days saw the battery light but didnt think much of it, my tech and my speedometer dropped to 0 and radio shut off, it has new battery cables and battery, so can also be the alternator?
