i have a rattling noise that happens at around 2500rpms if i accelerate slowly it doesnt rattle but if i give it a little more gas it rattles until it reaches crushing speed then it goes away what could this be your help would be greatly appreciated thank you
rattling noise at about 2500rpms
Originally posted by marcbh View Posti have a rattling noise that happens at around 2500rpms if i accelerate slowly it doesnt rattle but if i give it a little more gas it rattles until it reaches crushing speed then it goes away what could this be your help would be greatly appreciated thank you
i have the opposite problem
when i accelerate slowly it rattles
my car has alot of problems lol
i have the same problem and i can say with most certainty that it is not a heat shield.
i just took all of mine off and it still rattles.
its almost like a light lifter noise but its never very consistent and it only does it under load.
light rattling, not tapping, or knocking. doesnt increase with rpm. just rattles for a second and then goes away once you get further in the rpm range.
the best sound i can describe it as:
when you are in too high a gear or on a hill in a 22r toyota truck or a nissan z24 truck and you give it some gas.....
shitty explination sorry. but for those who know what i mean this might be pretty good.Last edited by H22Artman; 10-08-2008, 02:29 AM.
Originally posted by H22artman View Posti have the same problem and i can say with most certainty that it is not a heat shield.
My 5.7 LS1 Holden Ute
Originally posted by evil_demon_01 View Post
That sounds more like detonation, what engine mods/ecu do you have?
i thought detonation too since it seems to be a throttle/rpm issue rather than just a rpm specific issue.
gonna reset all timing/idle/spark adjustments in the a.m.
My car is making a similar noise also......it makes a softer rattle at EXACTLY 1650 rpms, and a louder rattle from 2000-2500 rpms in every gear under any acceleration force. However, it does not rattle when the engine is cold, only after the temps are normal.
I've been thinking it may be my CAT heatshield, but I've got a new catco cat less than a year old and it has hardly any rust on it and the heat shield is a very thick 12-14gauge material. I've thought about getting a shop to weld beads across the shield to strengthen it and prevent vibrations, but not sure if it would work. I don't want to remove the heatshield because water splashed on a hot cat isn't the best thing in the world....My Member's Ride Thread
Originally posted by marcbh View Posti found out what it was it the cat vibrating but ill get that fixed this weekend thanks to everyone for your input greatly appreciatedMy Member's Ride Thread
Originally posted by 19dabeast85 View PostIs it the heat shield on the cat or loose internals?
Well I just found what was causing my rattling noises! Evidently either vibrations or the header expanding/contracting broke the rear downpipe bracket. I found the broken piece nestled between the DP pipes and oilpan!:
