clutch =[
    clutch =[
    so today my cb7 left me sitting =[. i noticed last night my clutch was sticking. now today it wont let me shift i can push it in enough to start the car but it wont shift. this started yesterday when i left a buddy drive my car. the retard doesnt know how to drive stick. i guess thats what i get. any ideas of a easy way to fix this besides a clutch? =[
    my accord has been down for a week because of the same reason too...but i think you have to switch the clutch no matter what...cause the clutch might have been messed up somehow..anyways let me know if you find it anything new
      actually. my dad checked and my clutch fluid aka 3 dot brake fluid cylinder was bone dry. he drove it and it worked fine. the next morning i went to drive it it did the same thing so i got in the clutch fluid cylinder and pushed down the floaty thing and about 10 minutes later it was fine. every since the car has ran just fine.
        The fluid shouldn't be going anywhere... and it is. You have a leaky cylinder. Time to replace the master and slave cylinders. The clutch itself shouldn't be shot.
          i agree with him. If you do happen to replace the slave cylinder, it is a little tricky bleeding it and does not bleed as easy as the brake system does. Takes me about a half hour every time.
            U have to get a new one. No way around it
              i dont think i do. it was the first time i have ever put fluid in it since i had the car and since i did so the fluid hasnt budged.
                If your fluid was low, it's leaking. You need a new master cylinder, or slave cylinder. The fluid doesn't have anywhere to go otherwise.
                Buy new, or at least keep an eye on it, because it IS leaking.
                  Happened to me.
                  After having mine for a year and a half, the exact same thing happened. It was my slave cyclinder >< eek.
                  I drove my car home without using the clutch which was pretty fun.
                  For those of you who dont know how.
                  Step 1. Start the car in first gear and push the gas a little. after rolling a bit
                  pull it out of gear before releasing the gas. Hold the stick down on second gear.
                  Iti'll go in automatically while the rpm go lower. repeat for other gears.
                  Now for down shifting. lets say you want to go from 5th gear to 2nd for turning corners.
                  First pull it out of gear. then rev the rpms up some, like 3k to 4k and let go and hold it down to 2nd gear, it'll go in like if you were going in from 1st.
                  Red lights will leave you no choice but to turn off your car, put it in first and crank it on green.
                  HAVE FUN^^.
                  1991 Accord
                  2dr 5spd sunroof
                  H22a
                    You can go quite a while without changing the master or slave cylinder if you make a point of checking the fluid every two weeks or so. Figure out how fast the fluid goes down, then make a routine of checking it in time. Keep clutch fluid in the trunk and you'll be fine. I did that for about the last 2 years, and now I've just decided to replace my (leaking) slave cylinder. Because I don't like clutch fluid leaking from my car. But really, if you keep an eye on it you can go quite a while without replacing it, as long as the clutch hydraulic system is properly engaging and disengaging the clutch mechanism.
                      HAVE FUN^^.
                      hopefully i'll never have to use that info, but thanks for posting it.
