F22 in a CRX?
    F22 in a CRX?
    I have a 89 CRX. I was planning on doing a all motor ls/vtec, but then my buddy told me about a story in honda tuning. I read it, it was bizimoto's 460 horse honda insight. si it got me wondering.
    Cliffs:
    Is there a mount kit for this?
    Where can i find options for pistons, rods, valve train, cams, etc?
    Will a H22 tranny work?
    If it does, does that mean i can use H series clutch/flywheels?
    ANY help is greatly appreciated.
    Thanks,
    Crash
    a member here, F22HB, swapped a f22a1 into his 90 civic hatch.
    http://www.cb7tuner.com/vbb/showthread.php?t=67333
    something to look at, or at least set you looking into the right direction. hope it helps.
    My pictures/photos will return soon...
      contact ESP .. Explicit Speed Performance. they have the mount kit for the EF chassis which in theory should work for the crx as well.
      Originally posted by Devergote
      A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
        H and F series transmissions are interchangable, as are the clutch and flywheel options.
        www.bisimoto.com is the place to go for all things F22A
          i went on bizi moto and esp. i found some of the parts i will need but not all. i will still need pistons, oversize valves, and a intake mani/tb setup. I am going to email ESP on the mount kit, they have a h mount kit for a crx, im assuming it will work for a f motor too but want to be sure.
          Call me a newb but will h series pistons work in a f motor?
            Ya, its another basic swap now. Plenty of information if you search. It really should be easy with all the aftermarket these days. Seems like you can put anything in anything with bolton parts.
            Oh, and if you want to take the route of the other bolton swappers out there that go with F's or H's you'll need a B or D transmission. Mine has an F in it, but we had to beat the sides out to fit all that.
              i will most likely go with a jdm h22 trans, i don't feel like dishing out 2k for a conversion and trans lol
                Last I checked, the mount kits are for engines with none h or f transmissions.
                  hmm i will check into it when i email esp
                    from what i read in HT years ago, when bisi broke the 9 sec mark he was running a carbeurated F22 as well
                      just snag a b16 cable transmission and buy the F/B kit from bisi moto. That would be a perfect start for a all motor monster. Plus you dont have to worry about the change to hydraulic transmission
                        i snagged a 91 sedan civic for free and i was going to do this same swap (motor is bad), but then i snagged a b18 motor for 100 bucks
                          i already have a hydro b16 trans with a LSD, i just don't want to have to spend all that money for a f2b adapter
                          i still need info on pistons, intake mani/tb, and oversize valves. anything helps,
                          thanks,
                          Crash
                            www.bisimoto.com for internal parts. www.f22parts.com and www.tasauto.com may have some things as well.
                            An H23 intake mani and TB is the best you're going to get, other than custom.
                            As for the transmission, you need an adapter, or you need to find a way to run the H/F transmission. Those are your options.
                              i think you can get a H2B adapter from hasport to make it work too
