just installed strut bars and my steering kinda got tighter good or bad? an do i leave it on once i get my shock spring can arm setup?
strut bars
Originally posted by Kingtrae View PostWhat are strurt bars for and what's the difference between that and a sway bar
sway bars- body roll... you want these doesn't matter if you have power or not. Its good for everyday cornering. Hard or slow. Keeps the car from leaning too much. Some sway bars are adjustable. Depeding if your car is oversteering or understeering, you can adjust it to what you need.
Originally posted by jimy View PostStrut bars-chassis flex... you don't really need them if you don't make a ton of power. But hey they are cheap and they look cool.
Most cheap tower braces only "look cool", they don't actually do much because they typically aren't rigid enough. Don't bother if the brace isn't very rigidly constructed (including the brackets that attach to the tower tops, this is where most poor quality braces are defficient in rigidity). Good quality tower braces are a very worthwhile addition on most chassis.Regards from Oz,
John.
Originally posted by deevergote. View PostStrut bars help with cornering as well. Anything that stiffens the chassis will provide more direct response to steering input. However, too much can be unsafe on public roads.Regards from Oz,
John.
