ok heres the deal i have a stock f22a4 with a cold air intake and apc intimidator exhaust so i got the breathing down but i just want to make more power. its and automatic and its got a bit of miles on it and cant afford a re-build right now and just was wondering some tricks to get more horses besides nos or supercharger intakes or turbos im looking at making my car an all motor car! so is there any quick tricks?
i need performance!!!!
Originally posted by visualpoet View Postp12 ECU cheap instant 10 hp
Yes very easy, quick, and fun bump in HP. I did it and liked it.
well its a 1991 honda accord ex and for starters i i have just a muffler on it and i just took out the intake and cleaned all of that and i just did timing belts and serpentine belt and alternator belt and i just did the cam and crank seal and all the other necessary gaskets to do timeing belts and ive got a set of ngk performance spark plug wires in it and new distributor cap and rotor new cv axles and i was going to turn the distributer to advence the timing but dont know alot about that so....
There are no cheap, easy ways to do it. You could go turbo or get a used nitrous kit quite cheaply, but you'd have to know what you're doing so you don't blow anything up. Being automatic limits your options, since the old, tired autos can't handle very much abuse anymore.
The F22A has amazing potential, but you're not going to see it if you don't have some money to spend, unfortunately. Especially automatic.
if you get a ceramic coated header, wouldn't that be a waste of money getting the header wrap also? you'd think the ceramic coating would do the same job as the wrap already.
that and a DC header would probably go for $300+.
maybe get some lighter weight wheels? i mean it makes your car look nice while reducing weight.Last edited by Leung; 10-03-2008, 06:25 PM.
the F22B1 SOHC Vtec head wasn't really meant for performance but fuel economy.
maybe save a few more hundred bucks and do an engine swap?
oh btw, if you've already got an A4 header, i wouldn't waste your money on an aftermarket header unless your downpipe was already rusted and busted out because those aftermarket header designs basically mimic the A4's tubular design for better flow.
and also it has new ngk iridium plugs and it gets a can of sea foan motor treatment once a month because of crapy gas and also i only put it in the gas and i run high detergenated-30 weight quaker state oil in my car and i usually do an oil change about every 1500 miles and i heard that your supposed to use tranny suppliments every once in a while and thought that would help my tranny alot because it has slippage and cant figgure out what it is its only when i try to take off a little quicker then average not like a race launch though
Do not put ANYTHING in your transmission but Honda ATF. The crap people put in Honda automatics is what leads to their premature failure... well, second only to never changing the fluid.
If you have $400 to spend, you could get a nitrous kit. Of course, then you have to fill the bottle. With $400, you could build half of a decent turbo kit.
The F22B1 head is absolute garbage. Don't be sucked in by the VTEC gimmick. The F22A head flows much better.
Spend $50 on a junkyard head, and put $350 into having a machine shop modify it.
