so while im driving today my radio goes on and off then i look at my cluster and my rpm needle goes crazy for like a second so i pull over and rev the enine and it doesnt move, but when i turn my lights off the rpm guage works just fine does anyone have any idea of what could this be?
cluster goes crazy help!
[QUOTE=Shadow1;1692740]the ignitor or external coil could be going bad. i have the same issue. lol.
when the RPM needle go crazy, does the car's performance mess up also?[/QUOT
not sure i was parked and rev'd it just doesnt move but when i turn my headlights off it works, i never messed aroun wit the wirin or notin like thatStuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
Originally posted by Joshs92ex View PostMine did this too.
It was about 2 weeks ago.
But, it hasn't done it since.
I been thru this myself, check the negative cable off the battery, it splits in 2, 1 part grounds to the chassis, the other end to the engine. mine separated at the split. If that's not it check the the grounds by the thermostat housing if the bolt is loose, it will cause the same condition as the negative cable.
Originally posted by h22anow View Postcould be your alternator or your battery going bad, my alternator connection was loose so i connected it good and it got fixed.Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
