1997 accord dirt tracker
    hello all im bill .i run a 97 accord 4dr lx on a dirt track.last year i had a 87 prelude with a 2.0 won 17 in a row .my question is after say 5 laps on a 3/8 mile track in second {automatic} wide open at like 65 at best on the straights coming off the corners maybe 50 or so it will start to skip.now im an old fart and have been loving on hondas since the first gens.ive replaced the obvious {dist,wires plugs fuel filter}checked the cranktrigger it all seems fine.i will have the lead then it will slow its old ass down ,my problem is i have a helmet on and cant hear it well enough to find it .if you all could help i would appreciate it.
    one more thing we dont run exhaust so my second ox2 is weilded to the end of the pipe not burnt on lightly tacked on no codes in ecu thanks lots ill check back often.
    my cars are 87 accord
    1990 accord
    1990 accura
    1997 accord dirt tracker[ya gotta know the reason this one is a race car is because it was free no title]
    i run hydrogen generators on all but the 97 with great results if ya wanna know more just ask thanks
    bill
    This site is mainly for the 4th generation Accord, so you may not get all the help needed here. CD5tuner.com might be a better place, though it is considerably smaller (growing, but just a year old!)
    Anyway, the second o2 sensor isn't all that important for proper operation. However, if your ECU is throwing an error code because it's not hooked up properly, THEN that could cause some issues.
    What do you mean by skipping?
    It may be a spark issue... check into replacing the coil, cap, rotor, igniter... maybe even the whole distributor and see if that fixes anything. How about your plugs? Any oil leaking into the sparkplug tubes?
    I've been hearing about those hydrogen generators... I'm curious to see how they work. Definitely start a new thread and give us some information! If you're actually doing it, and seeing results, then it's a hell of a lot better than the speculation that we usually get regarding such things around here!
