I believe that's what i have. So what factory parts from other engines will fit? I keep reading about a4 headers and intake manifolds from other engines,etc.
f22a1, what'll fit engine-wise?
Originally posted by alkoholikwun View Postfor upgrades:
- f22a6 cams
- h23 plenum (upper part of intake manifold)
- h22a4 headers
all shall increase HP
Yea, most people go with the...
-f22a4 header (cause it's tubular design. Probably give you a little 4-5hp gain)),
-h23 intake manifold (some just use the plenum, but since you have an f22a1, without the butterfly system, you'll want to use the whole manifold, unless you get your hands on a f22a6 intake manifold, and bolt the h23 plenum onto it. It's up to you. The h23 intake manifold would work fine.)
-If you're gonna add the F22a6/H23 intake manifold, you'll need the Pt6 Ecu. It'll operate your butterfly system that comes with both of the manifolds, and if you're planning on upgrading to an f22a6 cam, the cam in the a6 is more aggressive than the a1/a4 cam, so the pt6 would help you out with that.
There's a thread on here with "how to make 30hp w/ less than $500". It includes all the goodies above.98' Mustang 3V Swap
11' VW CC R36
-h23 intake manifold (some just use the plenum, but since you have an f22a1, without the butterfly system, It'll operate your butterfly system that comes with both of the manifolds
VERY easy way to sqeeze out some extra hp for a cheap price.
