Ok got a real good one here for you guys....yesterday i was messin around with my car and i noticed that when i turned the turn signal on (left or right didnt matter which) i would get a fast blinker on the dash board and when i looked in the rear view mirror i noticed that the inside brake lights (the trunk brake lights) would be on but my outside ones would not be...instead my blinker lights would be on in place of the outside brake likes.....I've checked everything and replaced all the bulbs with new ones but it hasn't fixed the problem...any suggestions?
Tail light problems
pick up a used running light relay from a junkyard CB; this usually happens when the old relay circuit contacts start to crack.DEVOTE
FS: Lokuputha's Stuff
also check to be sure the bulbs match the sockets, like the single metal tip to single tip and double tip to double tip. Just a tip......for fixing your lights.F22a1, T3/T4 turbo, Greddy Type RS BOV on left-over AEM CAI piping, Turbo XS manual boost controller, PHAT intercooler, Crzy tuning, Walbro fuel pump, AEM FPR/fuel rail/pulleys/cam gear, Gude cam and throttle body, MSD ignition/cap/coil, NGK wires and Iridium plugs, Fidanza flywheel, ACT clutch, Nuespeed short shifter
9 lbs on stock internals (for 10 min)
16.2 1/4 mile with basics
??.? 1/4 mile with turbo
139 hp with all bolt-ons
??? hp with turbo
STAY TUNED
ive checked everything and i still cant figure out the problem....i dont dare drive it for fear of gettin pulled over and gettin a ticket....im probably just gonna have to have a repair shop take a look at it and see if they can figure out whats wrong with it1992 Honda Accord 4 door 5spd *Sold 5/9/09*
Originally posted by yeamans17 View PostHave you or someone else replaced your bulbs lately? Its possible that maybe someone switched the wires from the brake lamp to the turn signal and got the bulbs in the wrong sockets...may be worth looking at before you pay someone else to look at it.
x2. Check the wires/bulbs to see if any of them were flipped, simple problem solver.Still hustlin that Old Skool.......it never ends.
vv My Member's Ride Thread vv
http://www.cb7tuner.com/vbb/showthread.php?t=123371
