Tail light problems
    Tail light problems
    Ok got a real good one here for you guys....yesterday i was messin around with my car and i noticed that when i turned the turn signal on (left or right didnt matter which) i would get a fast blinker on the dash board and when i looked in the rear view mirror i noticed that the inside brake lights (the trunk brake lights) would be on but my outside ones would not be...instead my blinker lights would be on in place of the outside brake likes.....I've checked everything and replaced all the bulbs with new ones but it hasn't fixed the problem...any suggestions?
    1992 Honda Accord 4 door 5spd *Sold 5/9/09*
    pick up a used running light relay from a junkyard CB; this usually happens when the old relay circuit contacts start to crack.
    DEVOTE
    FS: Lokuputha's Stuff
      whats the relay look like cause i might go and get one tomorrow if i can get off work early
        also check to be sure the bulbs match the sockets, like the single metal tip to single tip and double tip to double tip. Just a tip......for fixing your lights.
        F22a1, T3/T4 turbo, Greddy Type RS BOV on left-over AEM CAI piping, Turbo XS manual boost controller, PHAT intercooler, Crzy tuning, Walbro fuel pump, AEM FPR/fuel rail/pulleys/cam gear, Gude cam and throttle body, MSD ignition/cap/coil, NGK wires and Iridium plugs, Fidanza flywheel, ACT clutch, Nuespeed short shifter
        9 lbs on stock internals (for 10 min)
        16.2 1/4 mile with basics
        ??.? 1/4 mile with turbo
        139 hp with all bolt-ons
        ??? hp with turbo
        STAY TUNED
          weird
            ive checked everything and i still cant figure out the problem....i dont dare drive it for fear of gettin pulled over and gettin a ticket....im probably just gonna have to have a repair shop take a look at it and see if they can figure out whats wrong with it
              check ground wires and contacts...
                ive checked everything and its all good so i dont understand why its doin that
                  Originally posted by yeamans17 View Post
                  Have you or someone else replaced your bulbs lately? Its possible that maybe someone switched the wires from the brake lamp to the turn signal and got the bulbs in the wrong sockets...may be worth looking at before you pay someone else to look at it.
                  x2. Check the wires/bulbs to see if any of them were flipped, simple problem solver.
                  Still hustlin that Old Skool.......it never ends.
                  vv My Member's Ride Thread vv
                  http://www.cb7tuner.com/vbb/showthread.php?t=123371
                    ive checked that and it doesn't seem like there in the wrong spots but ill give it a try and see what i come up with
