I'm trying to replace the rotors today, but I just couldn't get this nut out. It seems to be already beaten up but I tried to separate the nut just a little bit, but still tight. I've used an impact wrench with 400lb tq and breaker bar, still can't do it. Please help me out
Spindle nut removal, please help!
air compressor and a ir titanium air gun. works every time
92ex coupe h22
93 240sx with silvia front end (kadet in the works)
http://www.cb7tuner.com/vbb/showthre...=1#post1894990
he might have a friend that might have one. but the breaker bar with a heavier set friend would also work
92ex coupe h22
Yeah, those nuts are pretty tight. Make sure you tap out the lock from inside that groove. I got pissed off when I couldnt break mine loose with my 2ft. 1/2" drive Snap-On ratchet, I was standing and bouncing on it. Yeah, I turned that broken ratchet in for warranty two days later. I brought my IR 3/4" impact home the next day and it didnt even break a sweat on those nuts."Brought to you by Carls Jr."
If you dont unstake that nut and force it off it will cut your spindle threads. A 120v outlet compressor will work as long as it can put out 90-120psi pressure and has enough volume in the tank to operate the gun without dropping pressure. I use a 110v 30gallon craftsmen compressor for home, it works good."Brought to you by Carls Jr."
bring your breaker bar to the hardware store and get a 4-5' steel pipe at the hardware store that will fit over the handle as a cheater bar.(the kind of steel pipe they use for plumbing). (don't use a ratchet, it will just break the mechanism).
If your breaker bar isn't substantially built and you think it might bite the dust under this treatment, , you might want to drop by Autozone and borrow one of theirs before going by the hardware store. They lend out a really substantial 2' bar that I liked so much I let them keep my $$ and kept the bar for myself. It has a really big handle that actually won't fit in the pipe I usually use as a cheater bar, which is why I say go get it first before you go to the hardware store so you can get the right diameter steel pipe.
5' of length times say 120 lbs of force=600 ft lbs torque. that should do it. If you go wild on it and sit on it you can get more.
and it will only cost you 10 bucks, not 250 bucks like the really good impact wrench will.
of course, as others mentioned, you need to use a hammer and punch or whatever to "unstake " the axle nut before you do this.
don't forget to "stake" the nut back in when you replace it after the job is done.. it is a safety mechanism to make sure your hub doesn't come off the axle, no matter what.
bring your breaker bar to the hardware store have them cut you a 4-5' section of steel pipe that will fit over the handle as a cheater bar.(the kind of steel pipe they use for plumbing). (don't use a ratchet, it will just break the mechanism).
another good idea if you're able to is to support the underside of the socket so that it has less chance of tipping down and falling off and rounding off some of the edges of the nut.
hahahahaha just picturing a 140lb guy jumping on a bar trying to loosen a nut. guess i chouldn't laugh too hard tho, i'm only 149 so i could just as easily be the one jumping. i know, please forgive me.Originally posted by HardInThePaintGirls should most definitely rep the shocker. Embrace the shocker.
Be one with the shocker.
My ride: http://www.cb7tuner.com/vbb/showthread.php?t=187897
