i cant fuggin get pressure WTF i been trying for like 2days an 1 bottle no pressure any sugestion i double checked everything overtightened everything an still no pressure. when the fluid comes out it streams out rather than spitting WTF i need to get this working today cuz i need to move the car HLP
clutch not bleedin
Tags: None
what did you do to the clutch system already? did you remove the master cylinder?
you bled both the master cyl and the slave cyl?
make sure the slave cyl. release piston is engaged properly with the release fork/lever. maybe it's pressing out into the air instead against the release fork/lever . Then it wouldn't matter how well it's bled, it'd just be pressing in thin air.
also if at some point a an air bubble got trapped somewhere in the master cylinder that's past, and higher up from, the master cyl. bleed valve, that would explain the problem. The bubble would just stay there and wouldn't get bled. I don't think that's a realistic possibility due to how the master cylinder is aligned on the car, but it's worth considering whether that could have happened.Last edited by batever; 09-24-2008, 06:27 PM.
Originally posted by kelton View Postget a pump with a long hose, hook the hose up to the slave cylinder bleeder valve, open the valve and pump the fluid through till it comes up to the master cylinder
you have to bleed the master cylinder u before u put it in, its called bench bleeding.....and then once u install it u bleed it at the bleeder screw...if u just replaced the slave cylinder, u prolly let the system run dry, causing an air pocket inside the master cylinder, which u can try to gravity bleed, which means crack the bleeder screw, and fil the master cylider and let it try to flow, u dont need to pump the pedal yet, and then once u get fluid at the bleeder, u can bleed it like u normally would.....if that doesnt work u are going to have to take the master cylinder out and bench bleed itLost Motion Inc. Repair and Performance Automotive
i dont think its got nothing to do with bench bleeding as the fluid runs in a stream out the bleeder not spittin im think my M/c took a shit on me the rod looks a lil moist an i jsut cleaned it so ya.Last edited by GearBangnAccord; 09-25-2008, 10:43 AM.
Originally posted by GearBangnAccord View Posti dont think its got nothing to do with bench bleeding as the fluid runs in a stream out the bleeder not spittin im think my M/c took a shit on me the rod looks a lil moist an i jsut cleaned it so ya.'93 EX-R 5spd
if you take your MC line off dose it still just seep out or dose it spit then... if it dosent spit you got a bad MC as for the brake spring keeping the pedal down you can hook a bungie cord to the bottom of the pedal and the hook on your door jam where the front door latches... it usally takes a while.. if you got a buddy to help you then have someone pump the pedal and try moving the slave Cyclinder with your hand while he pumps the pedal... its worked for me before but i have had thoese nights where i bleed the shit for like 1/2 hour
http://www.pelicanparts.com/bmw/tech..._Auto/pic1.jpg
something like that with out that black piece at the end. Just connect that to the slave and start pumping and all the air will come out. Takes like less than a min lol.
