Upper Ball Joints
    You need to pop the lower joint to do the axles.
    Are you lowered? The clunk could be the upper control arm whacking the fenderwell. It's common when we drop 1.5" or lower, especially with corrected camber.
      Originally posted by Hondaisdashit View Post
      I was wondering if its hard to change them on the CB? if not then what do I have to do to install them the right way ? also will I need an alignment?
      any updates on your upper ball joints
      and i would do all the ball joints when i do the axles
        Originally posted by deevergote. View Post
        Replacing the whole upper arm is best. If you are lowered, or plan on lowering, I suggest the adjustable upper control arm from TASauto.com. I've got them on my car, and couldn't be happier.
        Do you get that clunk of the control arm hitting the inside of the fender with those TAS uca's? Or is the only real fix still to grind the top of the uca down?
          Yes, it happens with the TAS arms as well. It has to do with the geometry of the control arm setup in the CB7 in general. You need a small amount of negative camber to avoid the clunk.
            i have 4 degrees negative and it clunks just as bad.
            smoke tires, not drugs.
