I am going to Honda to get my tranny fluid changed and the guy said they don't do flushes because Honda doesn't recommend it. Why is that?
Honda says not to flush the Tranny!?
Originally posted by TypeG View Postit's because it can stir up settled particals and those particals can block up tiny passages in the transmission. i'd just do a drain and refill every oil change until eventually the transmission fluid starts coming out dark red. and use honda trans fluid. later.
and just when I was going to get this done. Thanks for the info
can I drain this my self ? if so how and were ?
Originally posted by Hondaisdashit View Postcan I drain this my self ? if so how and were ?
the drain bolt is here:
it has a square notch that you insert a 3/8's ratchet into. be sure to wipe off the magnet with a rag.
when you refill it, you add the fluid back in through the dip stick hole with a funnel. if i remember it takes about 2.5-2.8 quarts on a drain and refill. later.
Originally posted by Leung View Postshould we check it warm or anything?
http://www.d-a-p.com/Ads/dap-email7.htmLast edited by Fake Thug; 09-25-2008, 02:15 PM.
Originally posted by TypeG View Postwhen you refill it, you add the fluid back in through the dip stick hole with a funnel. if i remember it takes about 2.5-2.8 quarts on a drain and refill. later.Originally posted by Soichiro Honda, Honda Motor Company Ltd. FounderAction without philosophy is a lethal weapon; philosophy without action is worthless.
