I plan on road racing so boost is mostly out of the question. Should i build a freshly rebuilt H22 with a few upgraded parts or a built F22 and still run on 93 octane.
H22 vs. F22 which one to build
Originally posted by benjerman112 View PostBuild the F why not?
its a controversial topic. im bias, just look at my sig.
It depends what your goals are, as well as your needs. A swap will put you in a different class, as will certain mods. Read up on the rules from the sanctioning body you plan on racing under, and build according to them (keep in mind that if you're going to take your time, rules DO change... look at past changes and anticipate next year's changes...)
The H22 is more power out of the box, and with mild bolt-ons. Both engines are capable of pretty impressive power NA when built. They can both make over 300whp... but it won't be cheap for either one.
Also, boost isn't a bad idea for road racing, unless the rules prohibit it. Do your research. It may not be a bad option.
