Acceleration Vibration!!!!!
    I have replaced the motor mounts and done my timing and balance belt, and everything is on. When i accelerate my car shakes between 15-40 mph whether i am in first second or third any ideas on why
    umm i am assuming u mean the motor vibrates causing the whole car to shake then mayb the balance belt isnt in time, assuming this started after did the timing components.....if it seems like a drive line vibration could be a bad axle....i have had a few cars that vibrate a little from a bad inboard cv joint....this is all assuming that the tires are good and aired up properly, and that inner and outer tie rods are all good...those are the firdt things to check
    Lost Motion Inc. Repair and Performance Automotive
