heat shield...
    heat shield...
    anyone know how to remove the wire thing thats attached inside the heat shield... i know this thread is worthless but i need help on how to take the heat shield off.
    Hope this helps.
    http://www.cb7tuner.com/vbb/showthre...sensor+removal
    1993 Accord EX
    2011 Subaru STi
      i dont get it... i need to cut the wires off??
        What?
        No
        That is your O2 sensor.
        Remove it first by using an O2 sensor socket (do an autozone rental) than take the heatshield off.
          sorry.. noob here.... k bro thx... so i need to get a freakin O2 sensor removal crap
            Can't you just unplug the o2 sensor and pass the plug through the hole?
              dats wat i was thinking.. i was unpluggin that shyt out but its too tight... the owner before me was a pretty fcked up car guy
                If the plug is too tight, then replacing it won't work (DO NOT get a cheap splice-on replacement... they don't work properly... get an OEM Honda replacement)
                Unplug it. If it's tight, it has nothing to do with the previous owner. It should be a plastic clip. Just undo it.
                  imma go try to do it again tomorrow...thx
