help me with my window
    ok for about a week now my window has been getting stuck on the way down and I have 2 push it down while putting the switch down for my driver side window well yesterday it just got completely stuck Down and wouldn't go up or down then I left it alone for a few hrs and tryed 2 put my window up and it did but now it's fucked up again but this time it hasn't come back up anybody know what this is.please let me know thanks
    96 Impala SS fund:$300
    http://www.cb7tuner.com/vbb/showthread.php?t=86795
    get a new motor/regulator
    Originally posted by kc8enb07
    does it come w/ jdm trash? they better throw away gold in it
      Or it could be your rubber seal. JY simple
        what he said. i had the same problem on 3 of my windows before when i had my sedan
        Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
        -(B-Pillar Bar Originator)-
          Yes, it sounds like you need a window regulator; you can get a used one from a junk yard as long as they show you it works or they give you warranty.
          When windows goes up or down very slow sometimes can be the dry rubber seals which you can fix with some spray silicon.
            More often its the regulator/motor then it is dried seals keeping it from moving. Tho I have had a dry seal do that to me, so it does happen.
              yeh my passenger side window sticks from dry seals, but thats not gonna cause the window not to move completely i dont think....other than that see if it works from the paasenger side switch, if not then its a problem inside the door panel, prolly a bad window motor.....just check the switch first before u condemn the window motor
              Lost Motion Inc. Repair and Performance Automotive
                In the meantime if you can grab the top of the window, pull up on it while you are pressing the "up window" button and it may move upwards. Once it's up a little you can press up against it on the inside to help it up.
                  hey if you would like, when you get some regulators.... go ahead and buy me some too. sucks when my windows won't move and it's 95 dgrees in this fucking florida weather.
                  thanks
                    I just replaced my driver's side regulator last weekend. Mine did exactly the same thing, except sometimes the motor would click. Toward the end it wouldn't make any noise at all. Be careful to get the glass back in the tracks when you are putting it back in. I had to take mine apart twice more because of the stupid tracks! There is a 10mm bolt at the bottom of both sides to hold the tracks in place. You can take them loose and then put the window back in. Much easier than fighting with that piece of glass inside that panel.
                      awww... yes....the power window regulator. that thing loves to take a shit on me.
                      but i guess the last laugh is mine,cause my new coupe that i'm picking up doesn't have power windows.......yes i'm free...lol
                        I have the same problem. Mine is the rubber seals. They are so dry and sticky they will stop the window dead in its tracks. This eventually will cause the window regulator/motor to go.
                          benn having that problem too. my drivers door window goes down but at the end it'll stop and on the way up towards the end it'll cock foward and the rear corner will stick out completelly out of the door. i have try and push it back on the way up so it dont come out its a pain specially wen you have it all the way down and it starts to rain damm
                            Please try this before replacing your window regulator. Simply adjust the glass in the window. There are about five 10mm bolts that adjust the angle of the glass in the door and if the angle is too steep, the window will bind toward the top of the door and the motor will click because it cannot move the glass.
                            I had fits with my window jumping out of the track and even paid the dealer to replace the regulator but not until I got in the door and started messing with it did I discover it was never adjusted properly. I paid a lot of money to fix it but in the end I was the one who fixed it.
