adjustable cam tuning?
    any questions for the most power?
    Have anything to do with your other thread?
    Originally posted by fearlessracing View Post
    if you wanna see a real power increase that you wouldnt expect from 45 dollars then go on ebay and grab up an adjustable cam gear-retard it about 4-6 degrees and advance the distributor all the way. watch what happens man. it blew my mind.
      The butt dyno is completely different than a real dyno.
      By retarding the camshaft by nearly 2 teeth, you're moving the power band higher in the rpms. By advancing the distributor, you're trying to make up for the lost torque down low. You don't feel shit down low, but once you hit about 4k, it's like vtak hit or something. This my friend, is called being poorly tuned. A properly tuned/running car has a smooth and constant powerband.
      On a dyno, you would see a huge loss in torque, but a gain in hp.
      HP is worthless without torque in our beasts of a chassis. Not only do you lose torque, but you completely move the powerband to where its useless for about 90% of users on this forum.
      The stock f22 head/cam isn't very efficient above 6.8k.
      It sounds like all your "fearless ricing" experience sucks and is nothing but butt dyno, and not well thought out theories.
      **what I explained above applies only to f22 series engines. DOHC engines are a completely different story and benefit greatly from cam gear tuning.
        i think i will leave mine where honda put it thanx
