Originally posted by H22artman
View Post
Possibly a MAJOR problem
Did you try the putting something in the spark plug hole and cranking the engine by hand bro?
Let me know if theres any spare parts or anything you need I can go on a hunt in my neck of the woods. Im up in your direction every couple of weeks.
Hope you sort it out.. dont want a Maritime CB7 off the road!
Ok, so I'm about 90% sure that the piston ring came apart in there, whatever is hitting the plugs is bouncing around on top of the piston and is very small, but jagged because it's got the whole bottom of the plug banged up. Also it's smoking like crazy out the exhaust and sputters and rattles awfully. I'm very handy with cars but I don't mess around with internal components, and have a hundred more important jobs that need to be done before winter, so I wouldn't even get a chance to work on the car for a long time. I've decided to sell it for parts or easy repair, it's ready for an engine swap, hopefully I'll get enough out of the sale to buy another car. Hate to see it go, but can't fix this problem. Thanks for all the help guys
Check out my paintjobs at http://www.cardomain.com/ride/3134126
yeh i had a civic come in did the same thing...the piston prolly broke off the crank...the crank is prlly not bent or even bad.....if u need to save money just put a rod and piston in it and call it a day....ive done it, dont like to, but it can be done...providing metal in the from the piston breaking tore the cylinder walls up....in which case u really need a whole motor anyway...so think about it that way...for 500 u can take a chance, for 800 u know ur good....Lost Motion Inc. Repair and Performance Automotive
Well after talking to my mechanic and telling him the symptons he agrees that the piston ring has failed and come apart, and lil pieces of it have been hitting the plugs and causing them to be damaged. He claims that changing out the piston in these is very easy, so after talking to my father we agreed that we would make this our project. I'll either replace the piston and ring, or if this piston looks ok I'll just put a new ring in. It'll be off the road for a few weeks but it'll be worth it to keep all the work I've put into it. Finally a light at the end of the dark tunnel LOL
Originally posted by mean87 View PostWell after talking to my mechanic and telling him the symptons he agrees that the piston ring has failed and come apart, and lil pieces of it have been hitting the plugs and causing them to be damaged. He claims that changing out the piston in these is very easy, so after talking to my father we agreed that we would make this our project. I'll either replace the piston and ring, or if this piston looks ok I'll just put a new ring in. It'll be off the road for a few weeks but it'll be worth it to keep all the work I've put into it. Finally a light at the end of the dark tunnel LOLh23a3 lxinks
Yes. save your cb after all that work you done to it if I remember right you got like 397K miles on your motor, so just find nice low mileage engine and swap it plus you can change all belts and seals while it's out.
Engine removal Guide!!!
http://www.cb7tuner.com/vbb/showthre...&threadid=8849
Good luck
Originally posted by southsidecb7z View PostH22artman...so if you pull your head you dont HAVE to have it reworked? you can throw another gasket on it and ride?
good luck with the repair tho.
