Hi,
Just changed my timing and balancer belts for the first time, and I have a question:
after tensioning the belts, the crankshaft is about one tooth's worth shy (as seen on the balance shaft sprocket) of true north when the camshaft is aligned perfectly with a straigtedge to to engine head.
is this a problem? since the camshaft is slightly advanced of the crankshaft, the valves will start upening a tiny bit sooner than ideally, right? but I don't feel any interference right now rotating the engine thru the cylinders, and I can feel the input and exhause valve lash spacing at the top of each cylinder's compression stroke with 0.010 gauge valve gauge.
It ended up like this because when I tried tensioning the timing belt starting with both the crankshaft at true north and the camshaft at true north & aligned with the head, it ended up so that the crankshaft ended up 1.5 to 2 balance shaft sprockets' teeth past north. So I moved the crankshaft so it was slightly shy of north, put the timing belt on, etc, and tensioned, and I ended up with the crankshaft about 1 tooth shy of north.
Is it worth taking the belts off and doing it again, and is it really possible to get the crankshaft and camshaft perfectly aligned?? Since this is my first time I want to be sure. before starting it up and before finishing the valve adjustments.
The car isn't all the way together yet so it wouldn't 't be a super hassle to go back. just a little bit of a hassle.
thanks.
thanks.
